Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
- webmaisterpro
Well, I just tried to install latest Kunena 3.0 RC1, but installation freeze, showing the following message:
Here is my system information:
Database Version 5.1.68-cll
Database Collation utf8_general_ci
PHP Version 5.3.23
Web Server Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 2.5.11 Stable [ Ember ] 26-April-2013 14:00 GMT
Joomla! Platform Version Joomla Platform 11.4.0 Stable [ Brian Kernighan ] 03-Jan-2012 00:00 GMT
- webmaisterpro
Matias wrote: You have probably displaying warnings, which for some reason break the AJAX reply (a bug?). Are you able to see (by using FireBug or similar tool) what the AJAX reply looks like?
I have already revert to Kunena 2, as the test was done in production website. Just a guess, that the issue might be related to CloufFlare CDN. I might try to reinstall it once more in a time with less traffic on my website.
Must be something else.
BTW: if installer fails, you could also try to visit the component as it tries to run installer again.
- webmaisterpro
I also tried that, same error, actually not an error, just installation didn't go anywhere. I just checked other suggestion to try to install Beta first and after that RC, I will try this during the weekend and come back to report.
